Perform this procedure to disable Dynamic Host configuration Protocol (DHCP) server detection in Auto-sense mode.
By default Auto-sense DHCP server detection is enabled. This ensures automatic detection of the DHCP uplink ports in Zero Touch Deployment.
    enable
    configure terminal
  2. Disable DHCP server detection:
    no auto-sense dhcp-detection
Enable DHCP server detection:
Switch:1>enable
Switch:1#configure terminal
Enter configuration commands, one per line. End with CNTL/Z.
Switch:1(config)#no auto-sense dhcp-detection
